How to Load Test Your Battery
+ Reply to Thread
Results 1 to 25 of 25
Thread: How to Load Test Your Battery
  1. #1
    Seasoned Member Digger's Avatar
    Join Date
    Apr 2005
    Location
    Colorado Springs, Colorado
    Posts
    2,590
    Post Thanks / Like
    Default How to Load Test Your Battery
    Nobody wants to be stranded by a bad battery on a trip. Some just replace their batteries after they've reached a certain (arbitrary) age, perhaps wasting a battery that may have years of life left in it.
    A load test is the common man's best way to determine the condition of a battery.
    I like to do one on my battery about a month before leaving on a long trip. If the battery fails, this gives me enough time to order one from Hal and perform the swap before the trip.
    Here is how I do the load test the OEM Yuasa battery in my bike (my bike is in my signature):
    To do it like I do, you'll need a few basic hand tools and a load tester. A digital voltmeter is desired, but not required (assuming the load tester unit has a voltmeter). A laser (or IR) thermometer is also handy to have.
    Here is the load tester I use:
    500 Amp Load Tester
    I've had it a few years and am pleased with it. They go on sale from time to time for about 20 bucks less.
    Let's get started:
    First, you need access to your battery. Remove the port side cover. This just pops out, but be careful not to damage the cover.:
    You will now see the battery. Remove the trim clip holding the black plastic battery cover plate in place, then remove the black plastic battery cover plate:
    Next, remove the battery holder bolt (use an 8mm socket):
    You can now move the battery holder out of the way.
    The first thing you will test is the battery's unloaded voltage. I first burn off any "surface charge." This prevents the battery from indicating an unrealistically high voltage. Remember, you are stress testing the battery, not preparing it for a beauty pageant. If it's gonna break, you want it to be in your garage, not 30 miles north of Sierra Blanca, TX.
    To burn off any surface charge the battery may have, turn on the bike's ignition and select the high beam headlights. Let 'em burn for three minutes:
    Just for S&G's, I like to monitor the battery voltage during the three minutes the headlights are on:
    What you want to see is an initial voltage drop followed by a steady voltage indication. (For this test, my battery dropped quickly from 12.62 v. to 11.68 v. and then remained at 11.68 for the remainder of the three minute period). If your battery voltage keeps dropping for the three minute period, you may have a problem.
    After three minutes, turn off the ignition and then wait for five minutes. Measure the battery voltage after the five minutes have elapsed. My battery indicated 12.56 v., which is fine. If you see less than 12.21 v. after this procedure, you will need to fully charge the battery and burn off the surface charge again before proceeding any further.
    You will find a chart of voltages and charge levels on this page:
    http://www.yuasabatteries.com/faqs.php?action=1&id=30
    (Scroll down to the bottom of the page.)
    Here is another source of good info about Yuasa batteries:
    http://www.yuasabatteries.com/pdfs/TechMan.pdf
    You are almost ready to run the load test. But first, you will need to know the temperature of your battery. To get a rough idea, you can use the temperature in your garage. I use my laser thermometer and get a reading off of the battery case. Write down the temperature.
    Next, I remove the battery cables from the battery and pull the battery out far enough such that I can get the load tester clamps on the battery. The black clamp goes to the negative terminal and the red clamp goes to the positive terminal. I also position the test probes of my digital voltmeter on the terminals so I can read the battery voltage as the load test is being conducted:
    Here is my load tester:
    Here, you can see the clamps on the battery terminals. We are now ready to apply the load to the battery:
    Next, I quickly twist the load knob on the load tester until I get to 135 amps of load on the load tester's ammeter. (I use 1/2 of the battery's cold-cranking amperage rating of 270.):
    http://www.yuasabatteries.com/vehicle_search.php?action=showListing
    (The OEM battery is the YTX20L-BS.)
    After the desired load is attained, I count 15 seconds. You can count, use a watch, or use a timer. My load tester sounds a beep after 15 seconds, also. While the 15 seconds are ticking away, I keep a weather eye on my digital voltmeter and note the lowest voltage seen. It is normal for the voltage to drop slowly during the load test.
    After the 15 seconds have elapsed, I remove the load using the load knob and disconnect the load tester terminals and digital voltmeter probes from the battery. You may notice a "hot electrical" smell coming from the load tester, this is normal. The case will probably warm up some, also, after the test is completed.
    OK, you've now got the two pieces of data you need to determine the battery's condition.
    Although the voltmeter built into the load tester has indications that tell you whether the battery passed or failed the test, I like to use the table in this reference:
    http://www.rpc.com.au/products/batteries/car-deepcycle/carfaq4.htm
    So, using the chart in the above reference, I see that my battery passed the test. The measured battery temperature was 40 deg. F and the lowest voltage I saw during the 15 second test was 10.23 v. All I needed to see was 9.3 volts, so my battery passed with about a 10% margin.
    You've just stressed your battery, so it is important to recharge it fairly quickly to prevent deposits from forming. I hit mine with a 1 amp charger for about an hour or so.
    Reinstall the battery cables, button everything back up, and you're done.
    By the way, you may find it useful to keep a log of test results as your battery ages. I first load tested mine three years after I purchased the bike. The battery passed with a margin of 30%. Six months later the margin had dropped to 16%, and now (four years after I purchased the bike) the margin is 10%. I'm pretty certain this battery will get us through our upcoming 7000 mile business trip.
    Here are the economics of load testing your battery vice just replacing it every three years (note, however, that I've had several motorcycle batteries not make it to the three year point): Hal wants $104.00 for a new battery (not including shipping). If you get a battery every three years, you spend about $35.00 a year on batteries. I got this load tester on sale for about 30 bucks. Because of it, I've been able to keep my battery for four years (and counting). The load tester has thus paid for itself in one year and I've got an extra $5.00 (and counting) in my pocket to boot.
    Multiply that by my five motorcycles and it's better than wages!
    However, more important than the economics is the feeling that you're departing on your trip with a strong battery that will get you back home!
    Enjoying the ride,
    Digger
    AMA Charter Life Member #109
    '05; Non-ABS; Pearl Yellow; 71,xxx Miles
    I don't own a cage.
    http://www.astronautbiker.com
  2. Remove Advertisements
    GL1800Riders.com
    Advertisements
  3. #2
    Seasoned Member Dream Catcher's Avatar
    Join Date
    Oct 2006
    Location
    SW Ohio
    Posts
    3,072
    Post Thanks / Like
    Default
    Nice write up Digger!
    Probably more detailed than many would practice....
    but your detail emphasizes that you know of what you speak!
    Your making the point about battery awareness is more important
    than the exact way it gets done.
    I would suggest anyone who rides in areas not frequented by taxis
    and pop sickle venders.....
    who doesn't want to get into testing their battery....
    should visit one of the parts stores that check them for free.
    Next to my automatic digital load tester.... I like the carbon pile tester (just like yours) the best.
    07-Burnt Orange-ABS/NAV CSC TRIKE
  4. #3
    Contributing Member fiver's Avatar
    Join Date
    Sep 2008
    Location
    Central Ohio
    Posts
    71
    Post Thanks / Like
    Default
    Fantastic write up. Thanks for sharing. I will definitely reference this thread again.
    Today, I went down like an idiot. Low speed drop. I am fine and the bike is fine. My (patient) friend who was on a 2008 GW stopped and turned on his hazards for all of five minutes while I checked my bike, myself, and my gear. After deciding I was GTG and to keep riding, his bike wouldn't start!
    It was clear from the low headlight output that he had a dead / bad battery. Never would expect that on a NEW bike.
    I rode to a local store and got some crappy jumper cables. Fortunately this happened during business hours and the GPS found a parts store less than a mile away.
    Lessons learned for both of us: Carry cables, have an onboard voltmeter, and test your batteries. Today we both failed on all three counts. Of course all of that paled in comparison to the epic failure I demonstrated attempting a left hand U-turn.
    So we finally got the bike running and made it home. Despite my urge to hide in the house and nurse my bruised ego and shun the outside world for the next 100 years, I instead got my voltmeter out and we checked the like new GW that failed to start. 11.8 V at rest, even after just coming back from a long ride. We confirmed that the charging system was working, as with the bike running and blipping the throttle it exceeded 14V. Hopefully Honda will take this as a warranty claim. No reason for a battery this new to fail so miserably.
    In this case, a multimeter proved the problem, but to really put your battery through the paces you need some addtional testing tools. I have heard good things about the HF pile tester on other forums, after reading your post I will definitly pick one up the next time it is on sale or I have a coupon. I have a car with a 5 year old battery and it still shocks me that it starts even in cold weather. These test methods will keep me from replacing it too prematurely.
    Or worse, replacing it too LATE and finding myself stranded
  5. #4
    Veteran Member wingwing's Avatar
    Join Date
    Nov 2006
    Location
    Agrestic, Florida WW/MM
    Posts
    10,927
    Post Thanks / Like
    Default
    Great write up ... thank you once again Digger.
    I just replaced my batt after about 30 months.
    ... I could hear the bike was NOT cranking over as vigorously as when new
    and a a load test confirmed the batt needed to be changed.
    Installed a new batt and now the starter spins fast again like when the bike was new.
    Test your components but also learn to "listen" to what your bike is "telling" you.
    Dennis
  6. #5
    Join Date
    Sep 2008
    Location
    usually on your ignore list or in Ft. Lauderdale, FL
    Posts
    469
    Post Thanks / Like
    Default
    Nicely done Digger.
    I've had to replace a dying battery once, and the cost still makes me wince! I should have known better as it exhibited many of the symptoms but thought another few thousand miles...
    Now a load tester is on the list of tools to get to maintain my vehicles.
    http://gl1800riders.com/forums/image.php?type=sigpic&userid=41006&dateline=122770  7621
    08 GL1800ABS Black - Gone but not forgotten
    06 ST1300ABS Black - Gone but not forgotten
    ATGATT
    IBA# 30395
    SCRC 101 Road Captain
    ARRL Life Member - NS1A
  7. #6
    Join Date
    Apr 2005
    Location
    Posts
    2,590
    Post Thanks / Like
    Default
    Oddly enough, the battery in my ST1100 just failed a load test.
    The battery was still cranking the bike over just fine. However, armed with the data from the just-completed load test, I'll not be trusting that battery on any long trips.
    I do, however, feel comfortable using it for local duty while I wait for a new one to arrive.
    Enjoying the ride,
    Digger
    I don't own a cage.
  8. #7
    Seasoned Member Lucky 777's Avatar
    Join Date
    Jan 2004
    Location
    Carlisle Pennsylvania
    Posts
    2,852
    Post Thanks / Like
    Default
    Although on a somewhat smaller scale, your method is pretty much how we load test large battery plants for commercial and government communications facilities. Depending on the battery, our load test varies between 300 and 500 amps and the cells must maintain a passing voltage for at least 4 hours. Being able to monitor a battery under extreme stress for that long allows for some interesting observations. Usually about an hour in to the test the voltage will actually rise a little. This is due to the internal resistance of the battery decreasing slightly as it heats up. I always thought heating things up caused resistance to also increase. Weird stuff!
    Thanks for taking the time to post a very good and useful guide!
  9. #8
    Join Date
    Dec 2003
    Location
    Birmingham Alabama
    Posts
    1,122
    Post Thanks / Like
    Default
    Nice article. I recenty replaced my battery in December. This was the original battery and the bike is an '02. The battery had capacity to start the engine it just wouldn't hold a charge.
    Another point to remember about AGM batteries is their ability to hold a charge for long periods. When they no longer do this, replace the battery.
  10. #9
    Daycruiser
    Guest
    Default
    Thanks for this info, I think I'll set aside $3.00 a month for 36 months and buy the wing a new battery every three years.
  11. #10
    Join Date
    Apr 2005
    Location
    Posts
    2,590
    Post Thanks / Like
    Default
    Quote Originally Posted by Daycruiser View Post
    Day,
    Your technique will work most of the time. However, it would have left me stranded on several occasions over the years. I've had a few motorcycle batteries that did not make it to three years.
    Ride careful out there now, ya' hear?
    Enjoying the ride,
    Digger
    I don't own a cage.
  12. #11
    Seasoned Member PunkinDave's Avatar
    Join Date
    Mar 2004
    Location
    Bethlehem, PA USA
    Posts
    5,188
    Post Thanks / Like
    Default
    Great write up and very detailed and spot on!!! I would add the following..
    ALWAYS WEAR PROPER EYE PROTECTION!!! You are load testing a device at high current and there is a possibility of explosion..
    Most Auto Zone stores have a mobile load test rigg that is automatic and will give you a pass/fail.. Take the battery in and have them do it!!
    If you are on the road with a failed battery, most of the chain auto parts stores carry decent powersports batteries for the Goldwing.
    I carry a set of small jumper cables, they fit the little terminals better and store smaller in the rear corner of the right saddlebag..
    '07 CBR1000RR Fireblade "NESBA #74"
    '08 Triumph Rocket III Touring (SOLD)
    Dave's '03 GL1800 Candy Orange (Sold)
  13. #12
    Join Date
    Jan 2006
    Location
    woodstock,ga
    Posts
    9,353
    Post Thanks / Like
    Default
    Your efforts, Digger, are one of the things that makes this forum and it's members great. Thanks
    "Real" Big Dogs don't need to bark!
    It's only an "Old Man's Bike" if you ride it like one.
    IBA # 25105
    1000 in 24 (Certified
    1500 in 36 (Certified)
    1500 in 24 (Certified)
    Darksider # 37
    Double Darkside (on the slab)
    Bridgestone Bias-ply G701
  14. #13
    Join Date
    Apr 2005
    Location
    Posts
    2,590
    Post Thanks / Like
    Default
    Quote Originally Posted by Lucky 777 View Post
    ....I always thought heating things up caused resistance to also increase. Weird stuff!....
    I believe I've read in the past that the effect you noted is due to the fact that the higher temperatures cause the electricity-producing chemical reactions to take place a little faster within the battery, thus raising the voltage a bit.
    As I found out during my stint with NASA, battery science is a fascinating and highly interdisciplinary endeavor....with large knowledge gaps abounding!
    Enjoying the ride,
    Digger
    I don't own a cage.
  15. #14
    Join Date
    Apr 2005
    Location
    Posts
    2,590
    Post Thanks / Like
    Default
    Quote Originally Posted by ldr_doug View Post
    Nicely done Digger.
    Quote Originally Posted by wingwing View Post
    Dennis
    Dennis,
    Yep, it's been my experience that a properly administered load test will flush out a sick battery even before you start noticing sluggish morning cranking.
    Enjoying the ride,
    Digger
    I don't own a cage.
  16. #15
    Seasoned Member pidjones's Avatar
    Join Date
    Sep 2006
    Location
    Clinton, TN
    Posts
    4,082
    Post Thanks / Like
    Default
    Great write-up and pictures.
    I want to second the caution on safety glasses. In the 70's I had a battery jumped by a wrecker who luckily wore the glasses. It turns out that the battery was bad because of an internal open - when he applied the cables and wiggled, it arced and ignited the hydrogen accumulated in the top of the battery, resulting in exploding the battery top right off. I grabbed the garden hose and hosed him, the car, and my house down from the acid. He was fine (though wet), because he had safety goggles on.
    I have taken several batteries to Advance Auto Parts for load testing, including one that it turns out was dry - but passed fully after adding water. BTW, they did not have distilled water there, but there was a drug store down the street that I bought a gallon from, and left the remaining for the store. That was a battery on my '77 GL1000. Turns out, it failed to start after I had stopped at Advance for another part. What luck! They had a correct Yusa battery in stock, but I did not need it after watering and load testing (which includes a long charge). I patronize that store regularly now.
    Last fall I stopped in to have the battery in my cage replaced. A young lady was assigned the replacement job, but apparently had not been given the adequate safety instructions. I related my story of the exploding battery and waited until she had rounded up safety goggles before proceeding.
    Love 'em all... Let GOD sort 'em out!"
    LIMNCS #632 DS#1085 Michelin Primacy Alpin PA3 ZP #19
    Trialsman Seminar Videos
    Swapping the Rear Wheel by Laying Her Down (youtube)
  17. #16
    Seasoned Member ET Rider's Avatar
    Join Date
    Dec 2004
    Location
    Haines City, Florida London Ontario
    Posts
    1,226
    Post Thanks / Like
    Default
    I have an 04 1800. The bike sits all summer as I am up north for a few months. I started to put the battery on a battery tender in the summer of 05 and every summer ever since. I bought a replacement from Hal last year to have just in case. I want to do a load test now that the battery is 5 years old or more but don't want the expense of the tester. I just learned through my neighbor that the local auto parts stores will do a load test for you free of charge. When I get back I will have it tested and then decide to use for another season or replace.
    GWRRA # 215175 since 05
    USAF 1960-1964
    2004 GL1800 Candy Black Cherry
    I'm a geezer
    Prowler # 45
    A stranger is nothing more than a friend you havn't met yet
  18. #17
    Member
    Join Date
    Sep 2010
    Posts
    21
    Post Thanks / Like
    Default
    Very good write up, but for me, I stick to the every 3 years, since I don't have the tools and am to lazy to spend that much time doing it.
    Cheers
  19. #18
    djevanstn
    Guest
    Default
    Digger . . .
    I too liked this post, but, "Who's HAL, and why do you buy from him or that co.?
    I'm relatively new to this forum and if this (HAL) is the best place to purchase battery's, I'd like to know please.
    Don . . .
  20. #19
    Seasoned Member rmcapozzi's Avatar
    Join Date
    Aug 2007
    Location
    Leesburg, VA
    Posts
    3,812
    Post Thanks / Like
    Default
    Quote Originally Posted by djevanstn View Post
    Digger . . .
    Don . . .
    Hal is the gentleman that established this entire site. He runs (or use to) Direct Line Parts. DLP is the main sponsor of this site. Look at the top of the page. They sell many items for the GL1800 and many like to provide this very good company with their patronage.
    Rob
    '10 NT700VA (Wife's)
    '09 Metallic Silver GL18BM-Heli-MMTE
    '05 Vstar 1100 (sold)
    '89 CB1
    '90 GS500E (sold)
    '87 CBR600F Hurricane (bent it at the track)
  21. #20
    Seasoned Member ssncob's Avatar
    Join Date
    Nov 2010
    Location
    Crossville TN
    Posts
    5,083
    Post Thanks / Like
    Thumbs up Good Job Digger
    Good job Digger!! (even if you are Airforce)
    I've been trained by GNB Battery Corporation, and was a Master Chief Electrician. Your discussion was one of the best short and concise examples of battery life determination I've run across in a long time. BZ to you sir.
    Enjoy the Academy - I used to go glider flying there, love the area.
    Double Darksider #847
    IBA #54767 BB1500+
    Patriot Guard
    "I can imagine no more rewarding a career. And any man who may be asked in this century what he did to make his life worthwhile, I think can respond with a good deal of pride and satisfaction: 'I served in the United States Navy.'"
    President John F. Kennedy
  22. #21
    Seasoned Member Wing One's Avatar
    Join Date
    Nov 2009
    Location
    Mass.
    Posts
    8,485
    Post Thanks / Like
    Default
    Thanks for posting it,
    2013 Ducati 1199 Panigale S Tricolore
    ___________________
    06 Wing ABS, Dark Red, Fully Traxxionized
  23. #22
    Seasoned Member nightwing93's Avatar
    Join Date
    Aug 2010
    Location
    Caldwell, ID
    Posts
    107
    Post Thanks / Like
    Post Loaded Battery
    Not sure if Digger will see this or not, but I pulled my battery. I've only had this bike since August so it was the first time out. It is a "Power Source" brand, never heard of it. I took it to the Napa store and they had some fancy-smancy tester. I was told my battery had about 200 cranking amps. I then took it the O'Rielly store and they had the same meter and it showed 182 cca. I then returned home and reinstalled it into the Wing. Turned on the key for a couple of minutes to get the top-charge off. and watched the voltage drop from 13.3 to 12.7. When I turned the key off the voltage rose to 13 fairly quickly. I was then told I didn't need to worry. I did all this because I became concerned when my BatteryBug was showing 28% starting efficiency. The instructions stated one should look into a new battery if it was bellow 30%. Maybe the BB isn't all that reliable eh?
    Nightwing
    <nightwing01.wordpress.com>
    CMA since '78
    AMA since '82
    Wingin it since '77
    '01 Yellow (5th wing...)
  24. #23
    Join Date
    Jun 2007
    Location
    Elsewhere
    Posts
    11,202
    Post Thanks / Like
    Default
    Back to the top.
  25. #24
    Join Date
    Apr 2005
    Location
    Posts
    2,590
    Post Thanks / Like
    Default
    Quote Originally Posted by ssncob View Post
    ss,
    Thanks for the good words!
    I first got some battery "stink" on me when I worked for NASA. The Shuttle Program was looking at replacing the hydrazine-fueled hydraulic pumps on the Orbiter with big azz electric motors, running on batteries. I was the Astronaut rep on the team.
    Battery science is a strange and interesting field, indeed!
    Enjoying the ride,
    Digger
    I don't own a cage.
  26. #25
    Join Date
    Apr 2005
    Location
    Posts
    2,590
    Post Thanks / Like
    Default
    Quote Originally Posted by nightwing93 View Post
    Night,
    I'd say that the behavior of your battery sounds pretty normal.
    I wonder if they did a real load test at either of the stores you brought the battery to?
    Enjoying the ride,
    Digger
    I don't own a cage.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
