1 - 4 of 4 Posts
On my 02 when reversing , the bike will stop and I have to go to neutral and back to reverse to make it go again. Seems to be moving slower and with less power than it did before ad dropping out more. Some times I have to hold the clutch in to get it to move once the revere light is on. I have checked al the fuses and they are OK. Any help would be great!
No I have not but it seems to be working fine but I will check. Thanks for the idea,
reverse
From my own experience and from reading on here, the first thing to check when having reverse issues, is the cable adjustment under the right side panel. It's in the service manual and the adjustment is critical for the reverse function. If you don't have the service manual, do a search here and you should be able to find the instructions and diagrams. They've been posted several times.
Richard
1 - 4 of 4 Posts
