My 03 gl1800 keeps blowing the low beam fuse after i use reverse, stop, and disengage the reverse it will blow. I don't know if this has anything to do with it but I just installed LED low beams (which SUCK) and since installing them when ever i use the reverse, back it up, and disengage the reverse sending it to nutural it will blow the fuse.
I've searched this forum and others and it all seams to lead to the reverse switch. I'm planning on pulling the switch apart this weekend and cleaning the contacts but was checking to see if anyone has had this problem and may know a solution before spending a bunch of money. Thanks for any help you can provide, its much appreciated.
