Another thought. If it worked before the air filter was replaced, then the first suspect would be the harness around the airfilter has one of those internal solder connection splices that is bad, or one of the connectors that was taken off has a problem. You might try wiggling all the harnesses in that area (with the key on) and see if you can get the FI light to flash on.
