Hi, Techdude good afternoon!
I just taking a couple of pictures.
Your new pics/scales are good! Nice job.Hi,98valk
Please tell me what scale should I use?
But, does that rule out the sensor being faulty??Hi,
I have to confess to you I didn’t bypass the angle bank sensor. I’d checked the voltage with key on.
I don't want to step on any toes here, and bless everyone's hearts for trying to help out but, sometimes.....you know the saying about too many chefs... Just maybe the waters get muddied by all the multiple duplicate questions. Just wondering if maybe a fix would come quicker if just one guy was working on this.....And who better than Techdude? Again, I'm just throwing this out.......
Are you talking about the little 6 pin connector just in front and under the key switch? If so, it has no effect on the FI light or starting.Hi, Techdude Good morning
The meter panel connector had never been plugged in to the terminal during we investigation. I don’t know if it were relatively with FI light. I remembered there’s no FI light on when I put everything back on first time after air filter changed.
To summarize: It has no fuel pressure because it won’t run the fuel pump. The ECM is failing to turn on and do its initial sensor test and run the fuel pump to prime the rails. It doesn’t turn on the FI light and it won’t flash it either. The ECM is getting good power from the FI/Ignition relay when the key is turned on, confirming the bank angle sensor and the kill switch are both working and confirming that C25 is good with no meltdown/connection issues. The ECM has good grounds. The VCC power that comes out of the ECM to run the baro, map, and tps sensor is not there, and the ECM has been replaced with a new one. I don’t mind the ideas at this point, because I’m out of them. I’ve never seen this set of symptoms and without the bike in my hands, I’m at a loss as to what else to look at.Without reading through all 13 pages of this thread can someone summarize easily why we believe the bike has fuel pressure?
@techdude2000Are you talking about the little 6 pin connector just in front and under the key switch? If so, it has no effect on the FI light or starting.
Trailer trip!Yes. The 6 pin connector just in front and under The key switch. Thank you so much. Are you living far from New York City?
Not a movie. It’s a series…What a journey to read through all this and still end on a cliffhanger. Hope it gets resolved soon.
