1 - 4 of 4 Posts
Has anyone verified from either the service manual, or actually taken apart fairing, that the warm air vents on the '07 models do or do not have a butterly valve attached to the open closed lever located above the letft clove box ? thanks
The lever for the foot warmer door is cable operated. I had an 07 apart but did not see any 'butterfly valve'. It looked just like the 06 lever/cable
setup.
Chard Member
Take a look at the parts fiche for a '06. Item #1. You have a single cable that comes down to a "Y". The "Y" splits to each lower rear cowl to open the flaps. Nothing going to the "warm air" vents. The black vents pop/fall out just like previous years.
Sorry the pic is so honking big. Don't have a clue how to reduce it! :roll:
1 - 4 of 4 Posts
