1 - 1 of 1 Posts
I want to make sure other Forum members are aware of an issue I have come across. I have a 2008 Airbag model. I recently purchased a used seat from a another Forum member from another '08 Wing. I discovered that the plastic "TAB" that goes under the front cross member/brace are different. The tab on the seat I purchased will not fit under the cross brace above the fuel tank opening on my Wing. I checked with Honda and they have no explanation. So........ If you're buying a used seat make sure it will fit your Wing. And as a disclaimer, this is thru no fault of the member I purchased the seat from!
View attachment 68949 View attachment 68950
1 - 1 of 1 Posts
