1 - 4 of 4 Posts
would like to know if anyone has wired two power points together and ran to factory plug under left hand faring compartment if so did the fuse need to be upgrade if so to what amp.
Thanks to all.
My thought would be, if you did that it would depend on what items you are trying to power...if you were going to use the outlet for powering a
portable air compressor then the fuse rating would be higher than if you were going to power a GPS
The circuit under there is only designed for 5 Amps max no matter how many plugs or jacks you wire to it. Upping the fuse size will put your wiring in danger of a meltdown. It really depends on what you're going to run in them as to whether you will overload the circuit or not.
I have 3 sockets on that circuit, with a double USB plugged into one of them. I have my cell phone charger and my 7" GPS in the USB socket, and another GPS in another socket, 1 socket is open. This is my set up most of the time. I have a 5 amp fuse and it has never burned out.
1 - 4 of 4 Posts
