I removed the shelter to adjust the cruse and found what appears to be another 12 volt power source. This plug is located near the cruse adjustment barrel and lock nut. It is a red plug like the one in the left pocket. I think I have read about this one but can’t remember… How many amps will it handle? What is the “intended” purpose of this particular outlet, if it is in fact a 12 volt source? I will check if it is a “switched” 12 volt with the ohm meter after while.
