1 - 4 of 4 Posts
I need to replace the hinge on the left trunk pocket. I have all the parts, but can't tell how they actually go back together.
Does anyone have a diagram or video that shows how the pieces fit. The diagrams in the parts catalogs are not specific enough.
Thank you.
The door fits on a bit strange. There is a big rubber block that presses in place and is held in by a screw that actually holds the door on the hinge.
Removal:
after pocket is off and split apart....
remove screw from rubber block.
slide rubber block out.
move door to one side releasing from pins.
Install:
slide door onto hinge pins
push in rubber block in place
put in screw.
re-assemble pocket halves and install on bike.
Go to Ronnies Mail Order and look up the blow up picture of all the parts. It may give you a good idea.
1 - 4 of 4 Posts
