Ever since a local dealer "reassembled" my bike from doing the frame recall (in 2006), my cruise control has not worked. I have a feeling they forgot to connect it, but am not sure. The dealer did a sloppy job with reassembly. I found I had to go back and reassemble certain areas of the fairing that were loose. Anyway, I hope someone may have run into a problem with their cruise control not working after having the bike serviced or taken apart by a dealer. If you have any suggestions or tips to look at, please advise. If it is necessary for me to remove the housing and check, I am ok with that too. I simply want it to work again and don't want to bring back to the dealer. A note: the cruise worked the day I rode the bike into the dealer. They said they'll look at it, but will have to charge labor for the job because it can't be proven that they were the cause. Thanks.
