I recently inherited a 2004 Goldwing from my dad. It was a project we were working on together, but he passed away before we could finish it. Backstory is that the owner’s son in law had borrowed the bike, but had a falling out with the family. It was left somewhere and the kid moved away. After some time, the owner recovered the bike. but not until rodents had destroyed the harness. Owner elects to sell. Purchaser sees how bad it it and bails on the task of replacing the entire harness. That’s where my dad and I came into the story. We have never heard this bike run, nor had the guy we purchased it from. Bike was purchased with most plastic and seat removed already. We cleaned fuel cell (took literally days to get the goo out) air box, fuel pump/strainer assembly, etc. bike had sat a couple years. Harness replaced with used harness with same part number and identical plugs/color code, literally identical except without the teeth marks. Trying to get the bike to fire up but having no luck. Compression tested at 180 on 5 cylinders and 190 on the 6th. Plugs cleaned and gap checked. Spark verified on all cylinders, but stronger on left bank than right side coil. FI light comes on for a short test when key on and fuel pump cycles. Sidestand switch, neutral light, radio, emergency flashers, headlamps, etc all works. The only thing I see not working is the lcd has no display, but my dad did have it working because he got the mileage (30k) from it and my brother confirmed he saw the introduction screen as well. The battery has been on a charger and has a tad over 13 volts no load. Drops to about 10.8-11.0 cranking. Bike tries to start (hits) but not consistently enough to run. I e seen it spin up to about 1000 rpm when it hits several times in a row. If the throttle is cracked, it acts like it has ignition too far advanced and will pop in the intake. In addition, it will only crank a few seconds at a time because it seems as if every few revolutions it hits before top dead center and stops the rotation briefly before rolling through it. When this happens, the radio shuts off completely and then boots back up. Cranking with no power to the coils allows it to crank normally with no strange events. I had thought this was a fuel issue, but discovered a very strange anomaly. It tries to start, but will not. Application of a shot of starting fluid and it will not hit a single time until the fluid is cleared, at which time it will fire a cylinder now and then. A shot of starting fluid whil cranking immediately makes the motor spin as though the coils are unhooked. I’m completely out of ideas as to what’s going on here.
Do any of the experts here have any idea what my next move should be?
