Ā·
Might have a sticking valve but the compression numbers don't indicate that. Good compression and within +- 10% of each other š
Although he said he had fire (spark), plugs 'might' be bad (not all of them at least). However, the fact that starting fluid actually bogs things down indicates either he's flooding it with fluid, or he actually has a weak spark blowing out under compression. For as cheap as plugs are I personally would replace them and see what happens next.
Classic start with simple things, minimize the variables you're working with and move up the troubleshooting ladder. Also, do make sure the right coils are going to the right cylinders. Hard to boo-boo that but I have seen it once.
