Good Day All,
I have been looking into a problem I noticed this week. I have an aftermarket high output Alternator installed that I purchassed off ebay 5 or 6 years ago. I fixed my Digital voltmeter and noticred the higher voltage. Could have been a problem for a month or so. Was fine in June on 7000 km trip to Newfoundland, then the poor soldering on Chinese voltmeter gave out after 3 years.
- Upon repair of my digital voltmeter, it started showing 15-16.9 V at idle (seems to jump from 15-16.9 at times after total warmup seems to settle around 15.2V - 15.5V). I do see high 14's occasionally.
- meter across battery shows about 0.2 Volts less than the Digital voltmeter, but that can be adjusted later.
- Last night I shut bike down and battery was showing 14.3 volts when key off.
- Just checked this morning and it was at 13.2 V with key off.
- cranking voltage only drops to 11.5 and it starts quickly and bounces right back up to 15 region.
- ECM reset seems to work OK, but still hunting around 750 RPM after complete warmup (fans off/on). (from the wonky voltage it's getting I suspect).
- Bike runs great.
- All lights seem to slightly flicker including dash lights.
I have replaced ALL incandescant bulbs with LEDs. (Current draw much lower now I suspect). I did pull fuses from lights no change. Also disconnected back end via connector, no change. Only non-LED are HIDs in Low beams. High beams are LED.
I am really worried about frying the battery.
Anyone have any suggestions as to where I should start looking ? Wiring to Alternatlor ?? Fuses ? Battery terminals are great shape. AGM battery.
I don't want to get replacement alternator if it is not the culprit.
Thanks in advance for all your help in this ...
Steve
- Bike runs great.
Steve
