(This is probably too much information but please see if you can answer my question at the end.)
I recently rebuilt the right front brake caliper to fix a leaking problem. A long test drive of about three hours showed everything from that was working great.
Then we were leaving on a motorcycle trip earlier this week when it was 100+ degrees and the afternoon traffic on the interstate turned to stop and go. The temperature gauge started going higher and higher. Then the engine was responding poorly, the throttle was "weird," and my brake lever and pedal felt mushy. I got off the freeway, let the bike cool down a little, then returned the five miles back home on surface streets. Cancelled that trip and took the car instead.
After reading about the 2005 Goldwing cooling fans shutting off at 15 mph and bug accumulations gumming up the radiators, I thoroughly cleaned the radiators today and took it for a test drive in the same kind of traffic as before. This time I was watching events very closely to see what happened.
Even though today was only about 85 degrees, the temperature gauge began to rise after a while of slow, stop and go. So much for my cleaning the radiators to fix things! But then I noticed again the bad engine response and "weird" throttle. I realized that what was causing the issues were my brakes felt like they were "on" and got progressively more "on" as the engine temperature went higher. If I pulled in the clutch while still moving, the bike acted like I pushed on the brakes! The hotter the engine, the more the brakes grabbed. The braking was causing the engine to work harder and exacerbating the overheating! My throttle "weirdness" was actually a jump in RPM when I pulled in the clutch accompanied by an immediate slow down from the brakes.
I pulled out of traffic and it felt like the brakes were on the whole time. I couldn't even get going in 1st gear to get down the exit ramp. After sitting on the road shoulder to allow some cooling, the brakes released some and I got going off the freeway and onto surface streets without traffic. I watched the temp carefully and the bike handled better as the temp went down and was fine by the time I was home.
From my observations, as the engine temperature went higher, the brakes were engaging more and more without my control. I stewed about this for a couple of hours wondering how the engine temperature could be affecting the brakes. As I thought about the braking system, I felt the front brake line should be completely independent of the engine temperature. But the position of the rear brake fluid container on the right side of the engine could subject it to engine heat.
Could my problem be caused by me overfilling the rear brake fluid container after I bled my brakes? I was thinking about drawing down the brake fluid level and trying again but the bad traffic is over for the day.
