Do you have a Service Manual ???
If so go to the Anti-Lock Braking System > retrieval/erasure of problem code.
What code you got ???
I'll try to make it simple. Right front fork... The black wire that goes to the clip near the center of the wheel... remove the two bolts and pull the sensor and clean it. Bolt it back in place and test drive it.
Richard
Yes I have a Service Manual. I was all set to retrieve the code. Made copies of the procedure and went out to the garage with pencil in hand. No flashing, no blinking. Just a steady light. Decided on a test ride. The ABS light went out by the time the bike was at the end of the driveway.
:surprise::nerd::smile2:
For now, pull the stored code, write it down, and clear it. When it starts flashing again, pull the code again to compare.
