1 - 20 of 23 Posts
HUH!!?
Why the hell should we have to take off the seat to remove the rear panel & tire?:shrug:
You need to take off the seat to do anything on a goldwing, so all instructions start with that step first.
Just like most car manuals...the first instruction is "disconnect negative battery cable"
Take off seat?
Goldwing owners are usually older people and removing the seat to work on the bike will hopefully remind you that you took something else apart so you don't ride off with something dissambled.
Notorious Rocket Scientist
HUH!!?
They may have changed something on the 2012 model. Or it might be a mistake in the manual.
Best practice is to try it their way first and then you'll know for sure whether it has to come off or not.
Also tells you to remove the lower cowl to change oil and filter:wrong:
No, it's not wrong. It does give you more access to what you are doing, which you may or may not need. If you have a stuck-on oil filter and you have to get a pair of 18" channel-locks on it, you need the room.
That's as good of a reason as any!
Grumpy Fart
You are also instructed to remove the front lower cowl in order to replace the oil filter.
If you do find a short cut or time saving work around, do not post it online as your character and competence will be called into question.
laj, that is funny right there. But how often do you think someone would jump on to go for a ride and think, "Dayum this seat is hard today"?:lol:
Also on the 2012 to get to your battery you need to get into the saddle bag and remove a screw to get the side cover off........WTF
GM
GM
Maybe to make it harder to steal the battery? Not that I've heard battery theft was a problem; has that happened to anyone?
If any of the side covers needs a screw, it is the engine side covers. Many people have complained about those falling off.
Funny you mention the 18" Channel-locks. That's exactly what I had to do on my first oil change. Guess the last owner thought it neccesary to install the filter with a 1/2" impact gun..lol! I didn't need to remove anything else tho.
That' what I needed to get the factory-installed oil filter off at my first oil change. Which I was doing at midnight before a big trip the next day. Thank God for 24 hr. Walmart Superstores - I bought the biggest channel locks they had and that filter came right the heck off.
HUH!!?
If you are taking the rear tire off through the center panel the stereo amp must be removed. In order to access the connector for the amp you must remove the seat.
lmfao
I love WalMart. It was a little hard adjust for them to adjust their car lift to hoist the Wing, but afterthat they did a fabulous job with the oil and filter change.
Logical. So, who will be first to try laying the new design on her side for a rear wheel change?
Removing the seat will remind you that you should not ride the bike while working on it.
Some Wing guys forget that, and try riding their wings with all the Tupperware missing.
1 - 20 of 23 Posts
