Yep.
So if I buy the 2015 final, do I need to buy also the driveshaft?Yes !! But "not " the driveshaft !!!! 05 is shorter
With only 30k miles on it, I would make sure it was not overfilled and puking a little out the vent before I replaced the final drive. The earliest I have ever replaced a final drive was 60k and it had never had the lube replaced. I am not saying that is why but it didn't help things I am sure. I have a friend that has over 200k on his '05 model and has never replaced the gear lube. The average for the finals I have done is about 160k excepting the 60k one.Thanks, the bike is an 05 with only 30K miles, I saw the small leak on the final drive and from what I've read here that means that I need to replace it - bummer ! - I will keep the same drive shaft.
Why on earth would he never change the simple oil. Defying the ods:shrug:With only 30k miles on it, I would make sure it was not overfilled and puking a little out the vent before I replaced the final drive. The earliest I have ever replaced a final drive was 60k and it had never had the lube replaced. I am not saying that is why but it didn't help things I am sure. I have a friend that has over 200k on his '05 model and has never replaced the gear lube. The average for the finals I have done is about 160k excepting the 60k one.
