Anyone know how to remove and replace the painted mirror cover on a 2018 Tour? Took a low speed spill into a storm culvert and scraped it up pretty good. Found one online for $70 but can’t figure it out based on the OEM diagram.
Did a google search but no luck
Hope this helps...but honestly since your side panels are all scrapped up...I would not replace the mirror until you replace the side panels....
Once the mirror assembly is off you need to pry/pull bottom of mirror glass straight out and then top will pivot and unlatch. Once glass is off is just a matter of a couple screws and a push pin. If you search in the 2018 Tech Forum I asked this same question and have a diagram and picture on the thread.
Thanks all for the quick replies! I suspected the mirror glass had to be pulled out somehow, but was too afraid to give it a yank, as I didn't want to do further damage.
You guys rock!
