I changed the oil and filter on my 2021 GL1800 Tour a couple of weeks ago. I did it by by the book. I put the bike on the center stand, removed the filter, then drained the engine oil. I put the drain plug back in and then I took the bike of the center stand and placed it on the side stan and remover the drain plug again. I got about four more ounces of oil from the bike. I filled the filter with oil and installed it. Replaced the drain plug and put the bike back on the center stand. I put 3.75 quarts of oil in and ran the engine for about 5 minutes until the temperature gauge reached normal operating temperature. Shut the bike down and waited about 4 minutes and check the level. The oil level was about half way between the two marks. I added about four more ounces which brought the level to the full mark. I took a 200 mile ride and checked the oil after letting the bike sit for about four minutes. The oil lever was about 5 ounce over the full mark. I drained approximately 5 ounces of oil until the level was again at the full level. I have taken several rides since then and every time I check the oil it shows the oil level is again about 5 ounces above the full mark. If I wait until the bike cools down for a couple of hours the level drops to the full mark. If I let it set over night the oil level drops to the mid point between the two marks. What am I doing wrong?
