1 - 12 of 12 Posts
HELP!! I am on the road and I have a problem with my 2730, When I turn it on it keep's on flashing the startup page "STREETPILOT" Any suggestion's???
I suggest that you call Garmin tech support
- Monday - Friday
- 8 a.m. - 5 p.m.
Central time (closed holidays)
- 1-800-800-1020
- 1-888-442-7646
or
- (913) 397-8200
I have had this happen after a software upgrade. Usually disconnecting the power from the back of the unit resolved it temporarily. If you have done an upgrade lately, you may want to re-install it to the unit again.
Hope this helps;
Gord
I have just arrived back home, I have hooked it up to the computer but it will not log on to the computer just keeps flashing STREETPILOT.
I will get in touch with Garmin tomorrow
I received a update from Garmin with a fix for the problem, but it did not work tried a master reset which also did not work so I guess it will have to be sent off for repair here in Canada. (cannot be sent to Garmin in U.S.)
What age is that unit?
and how many miles have you ridden with that unit?
Do you think vibration knocked it out or was it a recent program change?
I have the 2720, two years old and did Route 66 (Read very bumpy) 5 times on a HD Roadking and it is still working properly.
Thanx!
2730
The unit is 9 month's old it has done about 20,000 mile about 16,000 of that on my wing.
It was in my van at the time I had used it to navigate to where I was, I left the van for about 30 minute's got back in and it just flashed STREETPILOT.
I have never had a problem with the unit and I do not think it was vibration.
I was picking my new wing up at the time (trailer -10c) perhap's it was upset at being made redundant!! LOL :lol: :lol:
P.S. it will never be redundant I will still use it on long journey's.
Does it have a harddrive or a CF card for the map data base. If it has a CF card, try taking it out and reinserting it. It may have vibrated loose just enough to make it unreadable.
Update
Picked up my Garmin 2730 today they replaced it with a new one. I was expecting that if it was replaced it would be refurbished.
They did not tell me what was wrong with the old one.
How did you determine that it is new and not refurbished?
1 - 12 of 12 Posts
