1 - 9 of 9 Posts
I believe I need to remove the grille covers in order to remove the top Tupperware, however I can't figure out how to get them off.
Any tips?
If you are talking about the Speaker Grills . . . they come off with the cover that surrounds the top of the dash including the Gauge Cluster. The hardest part of removing and replacing this piece is disconnecting, and then on reassembly reconnecting, the wiring for the Speaker Tweeters . . . although that's not really all that challenging . . . just a bit annoying.
Part of our flasher install video should help
Discussion Starter #4
Aren't there some screws under the grilles?
Discussion Starter #8
Sweet. Thanks for the link Bartman.
Discussion Starter #9
Cruiseman's new led replacement video does an excellent job of showing the removal of the dash. Thanks Cruiseman.
1 - 9 of 9 Posts
