I picked picked up a 2016 level 3 yesterday to replace the 2014 level 3 I totaled 6 six weeks ago. The PO said that he had the headlights upgraded. I found a work order in the paper work from a dealer that does say they installed 41-7336 led replacement bulb H7. When the high beams are turned on there is no change except the fogs turning off. The fogs turning off is normal but no change is headlamps??
Do all 4 headlights come on when high beam switch used or do only the 2 main headlights stay on and fogs turn off?
I am not sure exactly what your question is but If you look at the headlights from the front when they are turned you should be able to tell where they the put the 2 LED bulbs, they should look a brighter white than the standard halogen bulbs.
Now they are working. It was the high beams that are converted to led. No idea why they weren't working yesterday. They do look extremely bright.
