1 - 4 of 4 Posts
Hi I’m installing the Rivvco hitch, wiring harness and isolator. My trailer has a 4 pin hook up. Is there a converter anyone is aware of?
Is your trailer a flat 4 pin or a round 4 pin? And also does the trailer have LED lights? There are a lot of converters out there that will change the vehicle wiring over to a 4 pin output. But if you have the led lights on the trailer, you have to pay attention to the converter. I use this one on mine:
https://www.etrailer.com/Wiring/Hopkins/HM48895.html
The output 4 wire part was a bit long for me so I ended up shortening it. And if you have a 4 pin round, just cut off the 4 pin flat connector and wire in a 4 pin round vehicle side female connector
1 - 4 of 4 Posts
