HELP..I pull an Escape CSC trailer and until I damaged my plugs on a recent trip, the trailer wiring was perfect. I cut both sides last night and installed the Kury ball mounted wire plug system. Nothing is working correctly and I have moved wires around and tried different connections, nothing. My white wire from the bike is showing hot when bike is on, but that wire is identified as a ground. I tried to use pull apart connectors to connect all the wires to make it easier to dis-connect when I don't pull the trailer, may have been a bad idea. I use a multimeter when checking the wires and nothing seems to work except the white ground, showing hot and the brown showing hot for the running lights. I have the CSC wire diagram but at this point no use.
I have reached my limitations and need professional help. Any suggestions because at this point I may take it to a shop to have done. I have a trip to wing ding to compete in the top gun and don't want to go without my trailer.
Thanks for the help
Thanks for the help
