1 - 20 of 35 Posts
Hi All, I have to change my rr tire away from home. Tire developed a large bubble on the sidewall. If I lay it over to remove the wheel, should I be concerned about the oil going places it shouldn't. It will probably be laid over for a couple of hours. Thanks in advance.
no problem
You mean CT's get bubbles?
Make sure you don't have a full tank of gas...as little as possible. I dont' change the tire that way but I am pretty sure I have read this...I use the Center stand method.
center stand
If you don't have the audio package just put it on the center stand and take it off. If you have the audio package it may take a little longer...:lol:
rear tire change
I've done it both ways. It is much easier to lay it over, if you know how and can pick it up. I like to find a grassy knoll to lay it into. After it's on it's side pull out the center stand and clear enough angle to get the tire out. Try to have less than a 1/2 tank of gas. I've never had any issue with oil. Good luck with the change.
Richard
ease it over on a few thick blankets and you are good to go I did it a few months ago only down side is I smelled antifreeze for a week after
That's definitely laid over.
1 - 20 of 35 Posts
