Has anyone out there installed an accessory fuse panel and if so where did you mount it? There doesn't seem to much room under the seat.
I have a E/C connections fuseblock and it hooks right up to the stock battery box under the left sidecover. Works well and only took about 15 minutes to install :thumbup:
Mounted mine next to the battery and the ground connector under the seat. EC sells a really great ground block. Eight connections, I believe. Ya should do that too.
I did the same as LarryM....... Thanks for the help LarryM and IR Harry RIP...... I used the 8 pin fuse block. I also used a ground block under the seat from EC. This way I don't need to run everything back to the ...NEG... battery post, much cleaner.
I also ran a 60 amp push button circuit breaker to power my ACC fuse panel.... Lower right hand corner ( red box).
Lee
I have had ECs power block and ground block on all 3 of my GL1800s. They work great and are easy to install.
