There are 2 acc. terminals in the fuse block. On works fine and the lower one has now power. Any idea as to why? Are they fused separately? I only see one 5A fuse in the block, which when removed, kills the power to the top acc. screw terminal. Wanted to use both screw terminals. :confused:
The terminal without "Power" is the GROUND....
and if you look at the manual or fuse blocks you'll also note the imprinted + or - just aft of the the terminals screws.
now ,button it back up, put down the tools and go ride it!
