Nah.....if you’re rolling a stich, ya want a little grime on it. You know....”street cred” and all.....>Seems like once they get the dirty look it’s about impossible to get the new clean look back, many just sell it.
Eggzaklee.Nah.....if you’re rolling a stich, ya want a little grime on it. You know....”street cred” and all.....>![]()
The trick is to brush the entire suit with that oil for a consistent coloration.They don't clean very easy. I've got two suits and tried just about every method, and none have done much good. Yesterday I bought some oil and one of the caps was not sealed and I got various 3" diameter fresh oil stains on my Roadcrafter.Brushed some oxiclean into the stains, did nothing. Brushed some Nikwax techwash into the stains, washed the suit, then washed again with Nikwax waterproofer, then tumbled dry. The end result after this is the stains look 100% identical to what they were before.
My experience exactly. With about 30,000 miles on a hi-viz Darien coat, it was heavily stained with road grime. I washed it 4-5 times in warm water with everything imaginable, even tried to, "Shout" it out. Afterward, it was still about 90 percent as grimy as before washing. Also, water resistance greatly diminished after washing, and even the waterproof tape came loose around the neck. Later, when dry and laid out, I sprayed it down till soaked with Nik-Wax, but that stuff created stains of its own. I have ridden in the rain several times since, and water resistance is no where near as good as it was prior to washing.They don't clean very easy. I've got two suits and tried just about every method, and none have done much good. Yesterday I bought some oil and one of the caps was not sealed and I got various 3" diameter fresh oil stains on my Roadcrafter.Brushed some oxiclean into the stains, did nothing. Brushed some Nikwax techwash into the stains, washed the suit, then washed again with Nikwax waterproofer, then tumbled dry. The end result after this is the stains look 100% identical to what they were before.
Daaaaang. That thing is grungier than my hi-viz ever was. Did not think the gray or tan color would show dirt so bad. Thanks for the heads up. LOLPurchased my first and only "Stich" in 2002 it gets a bath once a year, not concerned about stains. I recently sent it to Aerostich for some zipper replacements, a wash & waterproofing, They were expensive then & more so now however the suit is every bit as good today as it was 17 years ago, & if I don't gain much weight I can see it taking me up to the whistle. jmop
That's not "Grung" joe, thats "Patina" (jk) although I haven't seen that many, I don't think I have ever seen one that didn't show the dirt, (unless it was new) I think it is the material, Mine gets a wash every year, & I use a spray waterproofing, I don't recall the name, the same stuff I use on my tent. I just sent it in for a couple of new zippers & a cleaning, maybe the pros know how to do it! when I get it back I will post a photo, A friend has a tan one & I think you are correct, it hides the stains pretty good, if I were to purchase it would be the tan. jmopDaaaaang. That thing is grungier than my hi-viz ever was. Did not think the gray or tan color would show dirt so bad. Thanks for the heads up. LOL
You need to be very careful on the products used on some of this technical material can tolerate.I need to find something else for water resistance. The bottle spray Nik-Wax does next to nothing, even after two coats that nearly drenched the suit. Per the instructions, I laid the suit out dry, then sprayed it down. I am thinking Scotchguard, or something for marine use, as dueling mentioned.
Wow. Everything you said !!! Couldn't agree more. Have had mine ( grey and black ) for about 25 years ( ? ) or so. Have never washed it. Stains ?? Unless you've spilled something directly onto the suit, who cares ?? Love the idea of Hi-Viz, but, one HAS TO know it's going to look bad/dirty after just a few years, right ??My experience exactly. With about 30,000 miles on a hi-viz Darien coat, it was heavily stained with road grime. I washed it 4-5 times in warm water with everything imaginable, even tried to, "Shout" it out. Afterward, it was still about 90 percent as grimy as before washing. Also, water resistance greatly diminished after washing, and even the waterproof tape came loose around the neck. Later, when dry and laid out, I sprayed it down till soaked with Nik-Wax, but that stuff created stains of its own. I have ridden in the rain several times since, and water resistance is no where near as good as it was prior to washing.
In light of the above, I consider this coat a throw away item, mainly due to its color. I will never own another hi-viz colored anything. I love the idea, but it just ain't worth the hassle. When it becomes too filthy, will toss it. Next time, will either go with gray or tan, or just go back to a good quality leather jacket.
