1 - 16 of 16 Posts
I've been running 40 PSI on my stock Dunlop 250 tires but thanks to a huge screw in the rear tire, I'm replacing my tires with Bridgestones.
Should I run the same pressures on the new stones or something else?
I hope I like these new tires. After researching, I decided to get these over the E3 and the rest.
Wow, I just put on a new set of stones for the first time, they are great, they stick like glue. I was told to run them at 41 front and 40 rear?? I have to tell you though I check them weekly and they always need adjustment back up in pressure. It is fall and getting cooler, that must be why?? Greg
My 02 came with stones and I've had good service. This being my first ever Gold Wing, I followed the service manual pressures for about the first 5000. On the set on the bike I've run 43.5-44psi in both and check em before every ride. Just ordered a new set. These have a bit over 22,000 miles on them and there is VERY little cupping on the front and they just hit the wear bars.
2018 Honda Gold Wing
I also run 38psi in the front and 41psi in the rear. I have tried running 41psi in the front tire and didn't see no advantage to running it that high. The bike seems to rides a little better with the front at 38psi.
Greetings,
The Bridgestone website indicates both front and rear tires have a maximum inflation pressure of 41 PSI.
The friendly UPS guy has a set on his truck for me today.
I think I'll go 41/41 and see what kind of life I get out of them.
Red said:
I've had great luck on a few sets of Stones setting them at 38f & 41r.
hey red........
do you use the 709/704 stones like the ones Hal has or do you use any other series that i see mentioned on occasion??
and do you know if the stones are hiding under rocks like all dunlops have lately.... my next set will be stones and i want to get my order in soon enuf so i dont get caught with no tread 8)
i still have decent tread left on my e-3's but im not happy with them when things get wet
I run 41/41 and have for a few years with the Bridgestones, I now have almost 18,000 miles on the front, unfortunately I have cut one back with a piece of glass and a nail punctured the next, so have the third one on the back since I put the front one on. I have already bought a new one for the front (stored) but this one just keeps going and going.
Pitre,
While at Wing Ding in Nashville this year, I talked with the Bridgestone rep, and he said they reccommend 39 front and rear, to allow for the heating of the tires.
Right now I have the stock 250 'lops on the bike, running 41 F&R. I have a set of 709 and 704's and I will try the 39 F&R when it comes time to replace them.
Mike
That's strange that they would recommend a different pressure than is stated on the tire. The pressure is supposed to be COLD PSI. I normally check mine cold and fill to the max pressure, or maybe down 1 lb.
I would imagine that the max pressures on a bike tire are like the max pressures for any other tire. They are the recommended pressures for a fully loaded bike. ie, trunk, bags, rider, passenger, and maybe a trailer.
You can run less pressure for day and commuter riding. That's my thinking on this anyway.
I have had Stones on the whole time...on my 3rd set, I think . I have an 01 with 53k on it and the tires now have almost 20k and I keep them at 41psi..front and back...I am going to put a new set on this weekend......they work for me...thats all that counts.....
bruce aka 'the blue traweler'
1 - 16 of 16 Posts
