I have an '09 GL1800 and it always seems that the AM/FM Sound Quality is crappy when the I/C is ON.
Can't find a solution in the Owner's Manual :cry:
Suggestions:?:
Crappy = ?
Low volume? Static? Distortion?
What brand of headsets do you have?
The headsets are the most likely culprit, but if they previously sounded ok, you could have lost the ground in the lower cord, and you could get the symptoms you noted.
You should have this problem with all sources, not just the tuner.
Intercom mute setting too sensitive. When the intercom is on it will mute the music when you begin speaking. If it is set to sensitive (low number I think) background noise will activate the voice activated mic and mute the music. Access by pressing the volume button on the center panel twice and adjust the setting up and down with the volume toggle on the left grip.
What Tulsawalk said!
