Wow, let me tell you all what I've been up to. Added All Balls, Sport Demon on the front, Euphoria on the rear, progressive springs in the front end and a new Traxxion shock and spring in the rear. Also replaced the air filter, added a voltmeter, installed a cb, and did the turn signal/temp display modification.
Well, it's been pretty cold here lately, and this has been a big project for me. I've been itching to get a few miles on, so finally I braved the 25 degree temps and went for it. Let me tell you, what a drastic difference in the ride of this machine. I haven't put on enough miles to get real agressive, especially at these temps, but I am glad I came to the dark side and look forward to warmer weather.
I wanted to make all these changes at once to feel the difference, and what a difference it is. Thanks to all who led me to the darkside, your recommendations are important to many.
Yep, I'll bet it does ride a lot different. Good luck with it all and welcome to the "Darkside":thumbup:
Good job on all your work. But you did it to fast if you took longer to do this work you would be closer to spring:thumbup:
mrwelaxn
On the downside you will not be changing tires for years!
Now what are you going to do all winter?
