I own one and the only drawback that I observed from as airbag model is it is harder to service. An example of this is the location of the connector for the heated grips. On the airbag model the connector is in back of the right radiator and you have to remove the right radiator to access this connector. It is a little harder to remove the airbags air filter and you sacrifice the right pocket for storage. The advantage is that I read about two bags being deployed in serious accidents and one definitely saved the individuals life. So I think it is a toss up. What I gave up in storage space and serviceability I make up in the knowledge that my chances of surviving a frontal crash are much better than with out the airbag. Also with the air bag model you have to be very careful how and where in install auxiliary devices on your handle bars and a tank bag is a no no.
As far as one deploying when it should not, it is almost impossible. I have hit bad road bumps, holes and railroad tracks while going over 85 and I one hit some speed bumps when I was doing fifty. Also around two years ago I drove off the side of a mountain road (long story) down the swale of the road for about 100 yards and the airbag did not deploy. (Ask slow Joe and preacher man) they were both there.
