In another post one of the guys suggested that if the ignition is accidently left on, it will turn off after 5 minutes to save battery, true or false inquiring minds want to know???
That would be a nice feature, many cars have it. Unfortunately the new Wing doesn't.:frown2:
Thanks Randy, no snide remarks just a straight up answer.
The same one who did the Nav system interface.In accessory mode (dash on, headlights off) the bike will shut off by itself after one hour. In run mode (headlights on), the bike will shut off only when the battery runs out of juice and the bike is dead. I don't know what idiot engineer thought that this was a good design.
When my bike is in the accessory mode it consistently shuts off after 40 minutes. Personally I have seen the time vary from bike to bike.In accessory mode (dash on, headlights off) the bike will shut off by itself after one hour. In run mode (headlights on), the bike will shut off only when the battery runs out of juice and the bike is dead. I don't know what idiot engineer thought that this was a good design.
That's strange that yours is different. You must have trouble with the nav updates? They usually take 40-45 minutes. If your bike shuts off you have to start all over again.When my bike is in the accessory mode it consistently shuts off after 40 minutes. Personally I have seen the time vary from bike to bike.
:doorag:
The same one that thought the fans blowing forward on the '01 thru '17 models was a good idea. JMHO>I don't know what idiot engineer thought that this was a good design.
This is my fourth time with haul bikes, once to Las Vegas and twice to Portland, Or., they were spot on the first 3 times, heres hoping for a fourth.Good luck with Haul Bikes... I contracted with them to transport two bikes when I moved cross country. NEVER AGAIN. If you can’t ride it, I’d drain the fluids and build a crate.
