Finished another valve adjustment today on a customers bike with 27K miles on it. All intakes were at center spec, had to adjust 6 exhaust valves.
Are they still shim adjusted?Finished another valve adjustment today on a customers bike with 27K miles on it. All intakes were at center spec, had to adjust 6 exhaust valves.
Yes, they use shimsAre they still shim adjusted?
And the GL1500 too!I still don’t understand why Honda will not use hydraulic lifters in the wing’s engine. The ones in the old NightHawk were fabulous.
Yes they were. Had a '98. Balancing the 4 carbs could be a bear though.I still don’t understand why Honda will not use hydraulic lifters in the wing’s engine. The ones in the old NightHawk were fabulous.
Saw this on Revzilla site - https://www.revzilla.com/common-tread/why-do-bikes-use-shim-under-bucket-valve-adjustersI still don’t understand why Honda will not use hydraulic lifters in the wing’s engine. The ones in the old NightHawk were fabulous.
So if I read this thread correctly the valves were all within specification.
Intake: .005” plus/minus .001”
Exhaust: .004” plus/minus .001”
What is your thought on K&N air filters? I had one on my GL1500.By the way, it's worth mentioning that the air filters in these new generation Wings seem to get dirtier a lot faster than the previous generation did. Here is one I pulled out of a different bike yesterday, with around 18K miles on it. I've done a lot of these now, and every air filter I've pulled out has looked pretty dirty at relatively low miles.
Cool.
From valve adjustments to air filters.
Dilly dilly.
:capwin:
. Interesting that you have to "undo" exhaust adjustment to do the intake adjustment.
In order to adjust the intakes you have to remove the cam to change shims, and in order to have room to remove the camshaft, you first have to loosen up all the exhaust valve adjuster screws to the max value.
