I'm about to rebuild the upper half of my ADV. When I remove the top bleeder valve,(as in Fred's tutorial: http://www.pbase.com/fredharmon/antidive ) should I expect that all the brake fluid is going to drain out of the brake line and master cylinder through that valve, or just the little bit that is in the top valve cylinder?
After I replace the O-rings and re-assemle the ADV, I will replace all the brake fluid in the system. Because I opened up the ADV, are there any other concerns I should have about changing brake fluid and bleeding the lines?
Any and all advice is appreciated. Thanx!
