Before I buy the Centramatics .. I was just wondering how it mounted on the front wheel with ABS .. ?
How it effected your ability to remove and replace a new front wheel .. ?
Thanks in advance for the input.
Theres no problem what so ever. They mount flush with the wheel then you reattach the rotors to the rim and thats it.I think the only time you should have to consider removing the centramatics is when your replacing the bearings other then that once the rotors are screwed back on the wheel is a complete unit. You dont even have to worry about removing anything when replacing a tire.
Cool, not a problem. They are a might dangerous though as they cause you to go around corners a bit faster.
Got ABS & no mounting problems; has not effected ability to remove/replace front wheel... just did it for mounting a new tire.
Ditto...my 06 w/Centramatics
08, level 3. no problems at all.
smooth, smooth, smooth!
