1 - 4 of 4 Posts
Anyone familar with MapSource? Need some help getting a map installed I have Mapsource installed on my home pc with the two 2008NT and 2009NT maps.
I have the 2009NT map also loaded in the Zumo 550 and it works fine.
My problem is I've now got a netbook pc, and I've installed mapsource with the 2008NT disk that came with the garmin, but I can't figure out how to get the 2009NT mapset to load. I don't have a disk, I downloaded the mapset from the website as one of my free one-time updates.
Any Ideas on how to get the Mapsource program on the netbook to have the same maps as the garmin?
Thanks for any advice or input you have!
Daveo
Good Idea. I just tried it. It only would work if I had a MAC. After reading the directions, they would allow you to continue to use the software and maps on both pc's though.
GOT IT WORKING: It required a registry hack after I installed the 2009NT maps on the new pc.
Now Mapsource can see both maps and I can select the 2009 map for all it's trip planning.
Yipee!
If you run into this same problem PM for the fix.
Daveo
1 - 4 of 4 Posts
