I decided since it was a nice warm day(102 degrees) and I was off I would replace my air filter. It should not take to long right. It took 3 hours. Had everything apart and back together in about 2.0 hours. Just as I was putting on the last couple of peices I realized somebody did not connect the radio antenna cable back into the radio..so back apart everything came.
There is a saying....." I do it right cause I do it twice."
Cranked it up and everything seems to work, I don't think I left any bolts or screws loose and all the wires are back where they belong, I should be good to go. :thumbup: Honda Goldwing sure does like to test ones patients and mechanical skills.
Yep you two are not the only ones who's forgot to connect something under the hood.
I once took out the instrument panel and found those wires are a bear to plug back in.
Sure nice to hear you have Someone in your garage.. :evil:
David
HondaMortch
The first time I did it, about two and a half hours. Second time down to an hour and three quarters. Practice makes perfect.
