I just bought a 2016 Gold Wing and I have a question about the USB cable in the trunk that does not seem to be covered in the owners manual. I have music loaded onto my cell phone can I connect it to the USB cable in the trunk and play my music from my phone thru the bikes speakers? I have a cable that came with my phone that adapts USB output to my Cell phone (Motorola v3) Thanks in advance
I'll bet it WILL play music from your phone as long as you leave it set up so the bike thinks it is an MP3 player.
The bike considers the USB to be AUX2. If you have the bike showing AUX on the screen, you should be able to toggle once more to get it connected to AUX2.
(You can toggle between AUX and AUX to with the bike controls.)
If I'm wrong about playing the MP3's from your phone thru the USB, an alternate method is to connect the headphone jack on the phone to the AUX input (3.5mm plug) in the LN front pocket.
If the pocket doesn't have the cable/plug in it someone has not installed it. If so, and you don't have one they are available from Honda. Requires popping out the pocket, plugging in connector and running cable thru the hole in the corner of the pocket. An idevice can also be played thru the 3.5 mm input - was the standard method prior to the 2012 model.
IMHO, life will be simplest if you acquire a usb stick (flash drive) and copy you library onto it. You can plug it into the USB and leave it there for whenever you want to use it.
1GB will be 10 or 12 hours of mp3 audio.
It's in your OM, but iirc the bike will read usb's between 256 mb and 64GB.
When we ran our '14's I ran about 4GB of data on a 'freebee/promotional' usb from some vendor. Still happily doing it's thing today on the new rides.
Edit to add: Like all forms or digital memory, usb memory sticks are no where near as expensive as they used to be.
