1 - 8 of 8 Posts
dnifong said:
What life span can we expect from the stock battery, and what mileage should I expect from the original brake pads?
thanks,
Dale
Dale, expected battery life for most recreational vehicles is about 2 years..(dealer says 3 years) and that can be greatly shortened if:
1. You have a bunch of accessories that might drain the battery like a security system
If you use a Battery Tender Plus, 3 years should be golden...if you plug it in every time you park your Wing in the garage.
On brakes....NORMAL average mileage would be 12-15K
Hope this helps.
Cheers.
I've got a 2001 with the original battery but I ride almost every day summer and winter to work. As for pads I haven't done anything with them. Haven't even looked at them but I just ordered a set from Hal.
LAW
Still using factory battery after 4.5 years. Have never used a battery tender or other charger on this bike.
Brake pads last me around 20,000 miles
Changed battery at 4 1/2 years during Hal's Memorial Day sale. Original is still holding a charge. 45k on original pads and just ordered a set from Hal's Labor Day sale. Originals are worn but not worn out. Down shift. Don't use the brakes.
just about 4 years on the original battery and 152,000 smiles, still seems to work just like new
replaced left front brake pads at 84,000
rear at about 99,000
front right at 136,000
if i were doing it over i would have just replaced them all at 84,000 but i was curious how long each set could last
1 - 8 of 8 Posts
