I recently suffered battery failure on my 2018 DCT, as recounted in the "A battery tale of woe" thread. The small town's Harley-oriented shop had a Yuasa battery that looked identical to the Wing's bad one, which I think was original, so I eagerly bought and installed it and finished my ride.
But that thread led me to examine the on-the-road replacement more carefully. It's a YTX20HL-BS, same physical dimension and color (white) as the bad one it replaced, for which I don't have a number. (The BS just means the battery's acid is "bottle supplied," added by the dealer at time of sale as a way to preserve shelf life. It's still maintenance-free.)
The Yuasa Application Guide shows the GYZ20L as standard in the 2018 Wing, but it's black and (what I think was) my stock battery was white, probably the YTX20L. In any case I now have the HL.
Does anyone see any potential problem with my continuing with this battery? Yuasa lists its application as "Gold Wing '02-'11 VTX1800C, F,N,R Retro,S". Compared to the GYZ20L, it's the same physical size, but there are a couple of electrical differences:
GYZ20L/YTX20HL: Capacity Amp-hrs (10 hrs) 20/18, Regular charge current amps 2.0/1.8, Cold-crank (0F) amps 250/310.
My non-expert thinking is that the much-larger CCA is good (that's what the H means), but that the slightly lower capacity and charging current aren't. But I think we're OK. (Finally, will I be OK using a Sears 2-amp battery charger? I don't imagine that 1.8 is an upper limit.)
