1 - 10 of 10 Posts
Looks like i may need new Battery i left key on and let it go flat what.Is the choice of most i have had good luck with Westco in the past where is the best deal price wise Westco or yusca.
As long as the battery was in reasonable shape to start with and it hasn't been discharged for a prolonged period, why don't you just recharge it? A battery charger would be cheaper than a new battery (and then you'd have the fix for "the next time"). If I would have discharged my car battery I wouldn't go buy a new one. I'd jump start it and let the alternator recharge it. Don't know about jump starting a Goldwing, though.
Don't depend on the alt. to charge the battery unless you are in for a long ride. Charging with a charger and/or B. tender would be the better way to go. If it is so dead the tender won't read any current and won't charge,fool it with a second battery hooked to the first one. As soon as it starts to charge remove the good one and it will continue to charge.
BATTERY
Thanks for the suggestions I have several chargers one of which is a Battery tender Plus.I plan on trying to recharge it I have some bike batteries don't like being run flat.
Some dummy left the key turned on and my '01 battery (original) went flat last summer. So I just hooked it up to the BT jr. and within 24 hours it was charged.
Battery was still going strong in November when I stored it for winter.
I have nearly 80,000 miles on the bike, and the alternator has done just fine. Why not depend on the alternator? The Batter Tender only puts out 1 or 2 amps, the alternator about 90.
From a dead flat battery I don't think the alternator is the way to go. A weak battery jumped started in a pinch is different. A lot of the alt. current goes to run the bike. I'm not saying it can't be done I just think the charger is a better choice if available.
Re: BATTERY
been there and done that TWICE :oops:
if your battery is down to 4 volts or below the battery tender probably won't work, its a built in safety thing
i would put a regular battery charger on it for about 20 minutes to get the volts up and then switch to the battery tender to finish charging
Thanks that is what i did I charged it with regular charger two hours then switched to battery tender Plus.I will know more in the morning looks like a nice day in the 60s.
1 - 10 of 10 Posts
