Sorry, I'm not an electrical guy... maybe this?
Joking about the fluid, but not my incompetance with electrical systems...
What happens when you activate the hazards?I'm running a 2010 everything but airbag, It started when I turn the blinker on and the dash light stays on no blinking, stays on for about 5 seconds flickers and goes out. Both right and left are the same. That lasted about two hours, now nether dash light comes on, but when I turn blinker on the mirror light goes out until I cancel then comes back on. I'm thinking blinker relay or switch. Any suggestions? Any help will be very appreciated.
Jim
Ok, does everything else on the bike work correctly?Nothing, no lights go on or off
Ok, so, the cancel unit is working correctly, it makes the running light turn off on the side you activate. With the hazard function and turn signals both dead, my best guess is the flasher relay has died. Since everything else is working, the accessory circuit power is good that runs the flasher. The flasher relay is behind the gauges, hanging in a rubber mount on your model year. You should pull the gauges and inspect the flasher’s harness for a broken wire or a loose connection, but I think you’re going to need a new flasher relay,yes everything works, no other problems, runs pretty smooth
Get it fixed yet?yes, my model is self-canceling, and yes, I change to all LED bulbs three years ago and put a LED flasher in
If you still have the OEM flasher, you could stick it in and see if they flash fast like it should with LEDs. If it doesn’t flash, then maybe there’s another issue.Although I gotta say, I washed it yesterday and when I turned the blinker on both right and left Light came on with mirror stayed solid for bout 5 seconds then flickered and went out. Maybe just a short some where.
