1 - 4 of 4 Posts
got wiring harness in the ok everything worked good got up sunday to go for a ride put in reverse back up about 10 feet the fuse was blown now the light just blinks
That fuse ultimately runs the reverse actuator motor that moves the reverse cables and the reverse gear. Double check the reverse regulator connector back in the hole on the left side of the frame and check the cable adjustments for the reverse. I would also unplug the actuator and see if there's a bent pin. Double check your wiring around the reverse actuator for something being pinched as well.
1 - 4 of 4 Posts
