Bike is a 2008 ABS with a serious braking system problem. Initial pressure on the rear brake pedal will drive pedal all the way down to it's stop. Pumping the pedal will bring the pedal back to a firm position but within a minute or two, the pedal will again sink all the way down under foot pressure. I've bled the brakes controlled by the rear master cylinder 3 times and each time showed no air bubbles whatsoever. There is no sign of fluid loss. Bleeds were done in the sequence specified in the shop manual. There sure seems to be air in the system but I'll be darned if I can find it.
As I understand it, there are additional bleed points and I have seen reference to the "Rocky Bleed" as a possible solution. Any help with this problem would be most welcome.
