1 - 3 of 3 Posts
I adjusted my clutch and front brake to setting 5. There is a rather large difference in distance between the two. My clutch is not as close as my brake. Is this normal? Is there any easy way to fix this, or is this a back to dealer fix? Had the bike a couple of weeks. THANKS
If the 2006 works like the earlier ones, you have to pull the lever away from the grips and hold it there while they are adjusted.
I did that. Have a 650 Burgman with the same adjusters and no problem, they are equal distance. Thought maybe Wing was different and if not how to correct.
1 - 3 of 3 Posts
