Looking for some hints here. I have no brake lights on my 04 Wing. Both switches and fuse checks out, any one out there have this come up and what was the fix??:shrug::shrug:
Thanks.....
Bad connection in this connector (C15). The green/red wire usually gets hot and melts the connector around the pins. It's the power wire for the brake lights.
I vote for a bum stop light relay if the only symptom is no brake lights. Have a trailer harness????
Thanks!!!!!
:thumbup:It was the wire as stated above, I had a relay ready just in case,
thats a BIG THANK YOU!!!:bow::superman1:
It had coroded pretty good, but I also noted the wire is really brittle, put in a section repair around the connector, did the ground wire too it looked bad as well!
THANKS again!!
