1 - 3 of 3 Posts
Do the brake lights on 02 work when you use just the front brake? If yes, what do I look for if they don't? Thanks
Joey
Thanks for the info. Headed to shop for switch.
Chard Member
Yes. Chances are you have a bad switch at the lever. Common problem. Less than $20 for the new switch.
Sent from iPhone
IronMan
Just did my switch last year -05- pretty sure if ya listen supposed to be 2 clicks . Mine had 1 and lever had to be in a zillimeter spot for brake to work. $14 at dealer. 10 minute job
1 - 3 of 3 Posts
