I have an 03 and have my bike down for replacing the Water pump and decided to change out the fluid in the front and rear brakes systems. I had the rear caliper off to change out the disk due to being worn. Got everything back togeather and open bleader then whent ahead and pumped the resivoir dry with the pedal then filled up the resivoir and began to bleed the brakes the brakes bled fine but after it sets and you push on the pedal it goes to the bottom have went thru several times but have not gotten any more air out of the system. any ideas or should I rebuild the Master Cyl
Ron
Ron
